How to Protect my block diagram coding?
Hi Friends,
I am having a Project in that i am having one Toplevel Vi and inside that there are various sub vis . Now i want to protect the block diagram coding  in my top level vi as well as inside my sub vis also how to do it can any one know??
Message 1 of 11
(4,589 Views)
Hai,
Do a search in the forum. You can get a couple of solutions.
Please post if further specific help required.
Mathan
Message 2 of 11
(4,586 Views)
  • Create an executable. Needs the application builder.
  • Make a source distribution of your application and activate the Remove block diagram option
  • Protect the VIs with a password (Ctrl+I to open the VI Properties dialog box >> Category = Protection >> check Password-protected). You have to do this for every VI.
Feel free to post back if you need further help.
Message 3 of 11
(4,584 Views)
Actually i tyied ur way but it is posible for me to saw the block diagram...................
Message 4 of 11
(4,578 Views)
First I would highly recommand to make your testing with a copy of your application !
What have you done ?
Message 5 of 11
(4,575 Views)
Yaaa Yaaa its working ..   but there are nearly 40 sub vis inside the top level vi ... how to protect from main vi it is posible
Message 6 of 11
(4,574 Views)
As far as I know, you have to activate the password protection for every VI, one by one.
Message 7 of 11
(4,566 Views)
Hi Karthikey...,
with LV8.5 you can create a source code package. There you can change the password for all vi´s in this source code package. I´m not sure, but with LV7 i think it works with the "save with options" function.
Hope it helps.
Mike
Message 8 of 11
(4,551 Views)
Maybe you can try this. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 11
(4,530 Views)
Message 10 of 11
(3,837 Views)
