How to Read Numeric Symbols Only within Specific Sequence of a String using Lexical Class Type
I had a look at some archive posts regarding reading specific characters in a string.
One that I was really enticed by was Altenbach's example using Lexical Class Type: Re: Removing non-alpha-numeric characters from a string
I have attached the VI so you can have a look.
The only drawback at the moment is that I only want to identify the first sequence of numbers and then stop. For example, I have a string which reads: An-54
Currently the VI indicator will be 54 because the for loop goes through the entire string. I actually only want 5 to be read because a special character follows. I am not interested in any numeric (code 3) afterwards.
Here are a few more examples to clarify what I want to achieve:
Input: AC1505
Desired Output: 150
Input: AI>00005
Desired Output: 0000
The desired outcome is for the match to occur with only the first sequence of number/s (from left to right) and stop matching once a different code (other than 3) is read.
Would anyone have any ideas on how to achieve that?
Many Thanks
(3,671 Views)
Accepted by neunited
Is there any particular reason for using the Lexical Class node here? It's a pretty straightforward regex. If you really want to do it with lexical class, you can make your loop conditional and use a boolean shift register to keep track of whether matching has started.
(3,652 Views)
Lexical Class is a better option performance wise in comparison to the "search and replace all" which is a multipurpose VI. For parsing and matching the lexical class seemed to be a more viable option to use.
However the issue now is that I actually want to include all minus signs and decimal places, for example:
Input: BK-0.03:
Desired Output : -0.03
One possibility could be by adding further conditions in the case structure or with the use of enums.
Let me know if you have any better suggestions.
Many Thanks
(3,591 Views)
I managed to solve my own query.
VI attached for your reference. If you have any other alternatives feel free to share them Smiley Happy
(3,584 Views)
I have my doubts that your lexical processing is more efficient than the regex and the regex is certainly more compact.
In almost all cases, I would expect the performance difference to be negligible. If it is important to you, I'd be curious to see how the benchmarks show out.
I think your approach could be further simplified to use a conditional tunnel on the output. You've also created an artificial stop condition in this case where you had to know that your last digit/term character was 3.
Your approach is the top one. My regex is the bottom.
(3,570 Views)
