I need the digital input that is available on the 9205 (slot 6 in 9172 chassis) module to monitor a float switch. When I try to add a digital aquire task in MAX it does not show any available hardware, though I can get PFI0 as a digital trigger under my AI Task. The 9205 manual specifies that the digital out is only available in cRIO, but does not say anything about the digital input. Am I missing something, or are neither digital in or out available on cDAQ? Is PFI0 as a trigger the only digital in?
