Problem with generation pulse (Width) by Counter
I didn't meet any problem when I used only one Counter, generated Pulse from external trigger, and changed Width on-fly. In loop I used "stop - set Width property - run" combination.
When system became more complicity the Width still changed by was restricted to ~75 ms!
Full system has
- PCI-6711
(2,711 Views)
Hi Vasilich,
It looks like you had a problem making this post because your other thread has a lot more information in it. Let's continue there.
http://forums.ni.com/ni/board/message?board.id=170&message.id=320232
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(2,692 Views)
