How to acquire and save the analog voltage values from DAQmx (I don't want the graph, but channels and values in a chart)?
Thank you so much. That is what I need. But there is a problem. The voltage I get from NI PCI6251 showed in Labview is -5 V, but when I use a volt meter to measure, it is 0.3V. I don't know where is the problem. Thanks.
Message 11 of 13
(579 Views)
Accepted by topic author Jshen6
Mark the post as solution if problem is solved.
Bijay
Message 13 of 13
(554 Views)
