How to acquire joystick data in host.vi application
I've a problem to intgrate joystick application to host.vi/FPGA.vi CompactRIO application.
Is there a methods to integrate joystick/keyboard as a remote controller to host.vi/FPGA.vi CompactRIO application because some of the component can't be use in these apllication.
Fendi
(2,760 Views)
Hi Fendi,
The joystick VIs on the Functions Palette use DirectX and are to be used on Windows and Linux systems.  I would suggest creating a Windows host VI that uses the joystick VIs.  Then pass any necessary information to your real-time VI.  Different methods for communicating between Windows and real-time VIs are explained here
Message Edited by Jennifer_R on 05-30-2008 07:30 AM
Jennifer R.
(2,738 Views)
Hi Jennifer,
Thanks for the info..
I've try using shared variable within 2 vi..
Its working properly...
Your Sincerely
Fendi.
(2,681 Views)
That's great Fendi.  I'm glad the information was helpful.
Have a good day!
Jennifer R.
(2,674 Views)
