Interpretation of flattended Variant
I have files containing flattened data of the data type variant. I want to intepret this data in Matlab. How can I find out what data type is hidden behind the variant and of how many bytes it consists?
Thank you!
(3,294 Views)
Hi dwoerner,
do you mean like this? Is it the string you write to a file and which you want to read in matlab?
Mike
Message Edited by MikeS81 on 06-23-2008 08:27 AM
(3,270 Views)
Here you can see what is written to a file.
The file looks like this: [FIFO Settings]
FIFO Settings="\00\00\16Ü\14D@P\00\08\02†@ñ\00\00\00\00\10FIFOSettings.ctt\00\02R\00P\00\05\00ª@P\00\07\00\12@\09\0C
and I like to use this data in Matlab
(3,264 Views)
Hi dwoerner,
that´s only the data, afaik you need also the type string to know how to read the data.
Mike
(3,259 Views)
Thank you for your help Mike
I think my files always have the same structure so I only have to find out once which data types are behind the variants. But I don't know which length a single flattened string has. I need to know because then I will be able to cast the specific bytes as the proper data type.
(3,233 Views)
Hi dwoerner,
is it a single string or an array of strings? A single string has 4 byte for the length and then the string. An array of string has 4 byte which shows how many elements are in the array and then for every element the structure of a single string.
Hope it helps.
Mike
(3,223 Views)
It's a cluster, so it can be anything. I would suggest heading over to www.openg.org and downloading the OpenG Data Tools. They contain many functions that make dealing with variants a lot easier. In fact, here's a simple example.
Message Edited by smercurio_fc on 06-23-2008 09:54 AM
(3,207 Views)
