How to activate functions on the front panel in run mode?
I think you r confused between "run mode" and "the program is running". Run mode can be acheived by clicking Operate----Change into run mode
whenever I change into run mode, I can't even right click or change or do anything for any controls or indicators. My question is how to unlock all controls after you change into "run mode"
Message 21 of 44
(1,080 Views)
And if you want the users of your program to be your friends, make it so they don't have to know anything about this "run mode" Smiley Happy It is a confusing name for this mode. It should be called something along the lines of "preview".
LabVIEW 2012
Message 22 of 44
(1,077 Views)
Bombbooo wrote:My question is how to unlock all controls after you change into "run mode"
Norbert already told you. Switch back to edit mode.
LabVIEW 2012
Message 23 of 44
(1,074 Views)
When you run the VI, the code enables all the disabled controls and you are fine.
Run mode itself is quite useless. Why do you think you even need to go to run mode (ctrl+m). Is there anything particular that you are trying to achieve by doing so?
Just run the VI instead!
Message 24 of 44
(1,073 Views)
I want to turn on run mode because I want to avoid the user movinfg stuff on the front panel. I might add some password for the user to be only able to run the program without moving anything on the front panel
Message 25 of 44
(1,066 Views)
Who are we considering "users"?  Are these people that will be calling your VI or people that will only be running it?  If they are only running it, build it into an EXE and your problem is solved.  BTW, you need to use a project in order to perform a build.
Message 26 of 44
(1,062 Views)
There are much better options. You have the 'Reorder' button that you can use to lock the controls. Besides building an exe, you can set the properties of the VI to run when opened. You have VI>Properties>Protection options. Why you be concerned about someone just moving controls on the front panel but not changing the block diagram is a mystery.
Message 27 of 44
(1,057 Views)
Thank you for the recommendation. I'll probably change my plan. I have another question. When i run the program, i cant scroll up-down the front panel window. Why is that?
I didn't lock the window. I locked only the data stream and some controls
Message 28 of 44
(1,049 Views)
I can scroll just fine when running the program. How are you trying to scroll?
Message 29 of 44
(1,042 Views)
Scroll up and down. Its locked
Message 30 of 44
(1,039 Views)
