How to add CDATA section in XML
I am creating a XML report, in these I would like to add CDATA section "to insert some set of character data.
I tried with XML example program, can anybody support me in this.
(2,789 Views)
What do you want to achieve?
Do you need to create new XML File Containing CDATA or need to add this content to an existing file?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,787 Views)
I would like to new XML File Containing CDATA
(2,777 Views)
https://forums.ni.com/t5/LabVIEW/createCDATAsection-with-MSXML-in-LabView/m-p/539640#M254405
Please refer the link above
(2,767 Views)
