Maximum sampling frequency
What is the maximum frequency which can be sampled in a LabView setup ?
I want to sample and reconstruct an analog signal of frequency around 6GHz. Is it possible ?
(3,381 Views)
Hi vysikanth,
the max samplerate is determined by the hardware you use!
Which hardware do you use?
I suggest to buy devices capable of those 6GHz measurements you want to take…
(3,364 Views)
I have been unable to find an NI made analogue input device capable of hitting that 6GHz that you are after (feel free to have a look ^^' just in case). I've included the links to some 3rd party products which seem to have NI compatibility might be of use and were the closest I could get.
http://www.signatec.com/products/pdf/Signatec-Digitizer-PCIe-PX1500-2-Data-Sheet.pdf
https://spdevices.com/newsletter-1
http://www.dynamicc4.com/sp_digitizer.html
Hopefully this was somewhat helpful
As stated, the maximum frequency will depend on your hardware. Interfacing this with Labview should not be a problem as long as the hardware is able to cope.
(3,344 Views)
