How to add a LLB as a file to a project?
I wanted to do the same thing and Ton's advice actually gave me the right hint.
Here is a somewhat more visual guide on how to add a LLB as file to a LV project:
1. Add -> File...
2. Select .llb on disk, Add File
3. Select the "top-row" and hit Select
4. Then you get the .llb addes as file to your project
Hope that helps somebody else as well.
Cheers Raeff
Working with LV2011, LV2018 and LV2020
Message 11 of 12
(453 Views)
Worked for me in LV 2015, thank you! 🙂
Message 12 of 12
(245 Views)
