How to add a Pause button in this counter
Hi Everyone,
Below I have attached a Labview VI of a counter. I want to set a "Pause" button that will stop counting until I press it again to resume. Can anyone help me in this regard?
I would be highly grateful to you.
Thanks in advance
Message 1 of 9
(2,487 Views)
Where does the counting take place?  What if you enclosed a key element of the count in a Case statement and wired a Boolean ("Pause"?) to its "selector"?
Message 2 of 9
(2,451 Views)
The boolean is used as a signal when the counter exceeds the limit. My problem is setting a "Pause " button in this program to pause and resume it. Thanks 🙂
Message 3 of 9
(2,401 Views)
This seems like a trivial first-day homework problem.
You did not specify the full requirements, for example you also have a decrement case. Do you want to be able to pause that too? Should it always count up and down between zero and the limit forever?
Some comments to your code:
  • You are dealing with integers, so there should be no orange anywhere. DO you know about numeric representation?
  • The terminal of Boolean should not be hidden inside a case structure. Do you even need it?
Message 4 of 9
(2,395 Views)
Thanks for your reply. Yes, I am new in LabView progarmmimg.
my requirement is to make a counter which counts continuously and it should have start, pause and stop buttons to perform their functions. No I don't need the Boolean inside the case structure.
Message 5 of 9
(2,381 Views)
Why would you need a start button? Just start the program in pause mode, then un-pause to start. You still have not explained the "count up" "count down" part. Is the user allowed to change the limit during the run?
Message 6 of 9
(2,375 Views)
There is no specific reason to add a Start button, just I want to know how to add those buttons to run a program. the count_down part I added to see whether I can do it or not. and yes user is allowed to use the counting limit.
Message 7 of 9
(2,370 Views)
Accepted by farhad11
Here's a quick draft (just counting up) to get you started. Now add all the other features. 😄
Message 8 of 9
(2,343 Views)
Thank you very much
Message 9 of 9
(2,327 Views)
