How to add an element to control's Properties?
I have a task to create an XControl, which has the ability to set a limit for the input string length. I found a good example, made by Prabhakant Patil, and it works like a charm. My only problem is that the limit should not be set by using property node, local variable or any other "programmatic" way, but instead like shown in the picture:
It's okay for the XControl to have property nodes and variables, but the user wants to set the limit in VI differently. I have not found a way to accomplish this, but I wanted to be sure. Since people here on forums are much more wiser and experienced in LabVIEW than me I figured someone would know how to do this. Or tell me it ain't possible.
I'm using LabVIEW2014 and Microsoft Windows 7.
-RautSa
(5,018 Views)
You cannot modify the default property dialog.
However, you can create a custom context menu for the XControl which calls a configuration VI looking similar to the property dialog. This dialog has to be implemented by yourself.
Norbert
Norbert
Expert: Geometry
(5,014 Views)
In your facade VI, trap the "Pane": Shortcut Menu Activation? event.  There setup the custom menu you want.
Also trap the "Pane": Shortcut Menu Selection (User) event.  There process the menu selection.
Dig through my XControl template for an example
(4,978 Views)
Accepted by RautSa
You can creaet your own VIs and make them show up on ctrl's property tabs.  Looks exactly the same as shown in your picture.
https://lavag.org/forum/23-development-environment-ide/
Keep in mind that, the ctrl property window only works in LabVIEW, won't work after built into exe.
George Zou
(4,964 Views)
This seems to be exactly what I was looking for. Thank you very much! Is this what
This I have not yet looked into, I'll have to get it downconverted first. Will this work in edit mode, or only in run-time?
-RautSa
(4,914 Views)
@RautSa wrote:
[...] Is this what [...]
-RautSa
Kind of. Thanks George for linking that stuff.
My idea was to create a complete separate properties dialog. This has the advantage that you can make that dialog accessible in runtime as well if required...
Norbert
Norbert
Expert: Geometry
(4,895 Views)
Is there a more recent link for the example? On lava there is only an outdated webring.com link.
(2,212 Views)
