How to add domain account manager to executable?
Hi All,
LabVIEW 8.6.1 + DSC 8.6.1
I have created local domain and some test users by using domain account manager. I also set user access levels to frontpanel indicators and controls. After that I build an .exe from my application.
When I install  or move this application to other computer how I can also transfer my domain configuration to that second computer. It is assumed that these computers cannot be in same network..Can I someway add domain account manager to executable or should I install manager manually that second computer. I can't install whole labview that second computer...
BR
(4,362 Views)
Accepted by topic author SnowForest
You can copy the directory located at Program Files\National Instruments\Shared\Domain to the same location on the destination PC. Be sure to restart the computer to apply your changes.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,356 Views)
This is a very good hint but as I said I don't want install LabVIEW to destination PC. Should I first install DSC runtime system or something else? I just wondering which program have created this folder structure to destianation PC...
BR
(4,338 Views)
You will be installing the LabVIEW runtime engine to work with the LabVIEW executable.
Message Edited by Adnan Z on 03-13-2009 12:13 PM
Adnan Zafar
(4,336 Views)
