How to update the Left shell string in Tree Parallely
Hi Friends,
 I am using Tree Control and subpanel in the same front panel.....  For example the subpanel will load the authentication.... in that he user will enter the name ... at the same time while the user types i want to update that value in the Tree control ..... how to do that....parallely.....
(3,594 Views)
One of the right-click menu options on the string control is "Update Value While Typing".  If you select this option, then you'll get a Value Change event firing every time someone enters a character in the string.  You could use these events to update the Tree cell as the user types.
(3,588 Views)
I never knew this before! Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,579 Views)
I guess that means it would make a good nugget...I'll add it to my list.
-D
(3,560 Views)
But I already knew that checking this option will update the indicator connected to it dynamically. Smiley Happy
So, from this info, now I can go ahead implementing this feature as a User Input option for even ML Boxes & Tables.
(3,551 Views)
