How to add more samples to a waveform
I have a waveform of 100 samples. I want to make the no: of samples to 1000 without changing the shape of the waveform. How can I do this.
Message 1 of 12
(5,190 Views)
Accepted by Flamboyant
Hi
The Append Waveforms.vi. You can find it in the Functions palette under Programming->Waveform->Analoge Wfn.
Make sure you read the help concerning how the dt and t0 of the waveforms you are appending behave.
Best Regards
David
NISW
Message 2 of 12
(5,188 Views)
I am not trying to append two waveforms. I just to increase the number of samples in the exixting waveform without affecting its shape. To be more clear just the opposite of Decimation.
Message 3 of 12
(5,176 Views)
Oh, so you want to interpolate to get an additional 900 samples in the same timeperiod? Is that what you want to do?
Best Regards
David
Message 4 of 12
(5,169 Views)
Exactly..........
Message 5 of 12
(5,159 Views)
Hi Cooldude,
But what extra values should be allocated to the 900 samples? They do not exist actually.
Regards
MY
Message 6 of 12
(5,153 Views)
I don't know whether it is possible. I am just checking out whether this is possible without affecting the shape of the waveform
Message 7 of 12
(5,148 Views)
Hi
Something like this could do the trick.
You would just have to build the X array from dt and t0 and also the Xi array with the new X values you want new Y values for. Standard interpolation
Best Regards
David
Message Edited by Davidek on 08-06-2009 04:03 AM
Message 8 of 12
(5,140 Views)
oh, and you would have to input the new dt into the build waveform as well. Sorry, forgot that part
/David
Message 9 of 12
(5,136 Views)
Hi David,
that is amazingSmiley Very Happy
Regards
MY
Message 10 of 12
(5,126 Views)
