How to add or multiply the waveform with shift register result
Thank You for the Suggestion I tried with removing the N in for loop. I have connected the  NI DAQ which is generating signals with continuous signals to analog output channel of NI-USB 6251. But i didn't got the result which can be viewed through Digital Oscilloscope. I have attached the pic of the same. Also I got an error message after running the VI for sometime.
Please help me
Thank You
Message 11 of 19
(1,410 Views)
Hi prasad,
there is no timing in your VI to limit the rate of waveform generation!
Right now you try to create new waveforms as fast as possible, but the DAQ device cannot output those waveforms fast enough - and so the DAQmx internal buffer overflows…
To learn about output of analog waveforms you should examine the example VIs coming with LabVIEW and DAQmx. There are also examples expaining how to output waveforms (using plain DAQmx functions)!
Message 12 of 19
(1,407 Views)
Dear Sir,
I have modified the VI with DAQmx generation. Still finding the difficulty in getting the output by NI USB-6251. Please suggest any modification to the VI
Message 13 of 19
(1,390 Views)
Hi prasad,
Which kind of "difficulty"?
Do you get any errors?
Why do you init and clear the DAQmx task in the loop?
Why do you have an inner while loop, set to run FOREVER?
Why do you set the DAQmx timing to use a waveform, but wire a DDT wire to this function? Why don't you use the waveform datatype?
Message 14 of 19
(1,370 Views)
I Created the inner loop because i was getting a error not buffered hardware timed operation for the USB device. How to use waveform data type to DAQmx timer. Please suggest.
Thank You
Message 15 of 19
(1,364 Views)
I am Not Getting the output itself from the loop after the modification. I have attached VI
Message 16 of 19
(1,355 Views)
Hi prasad,
see this:
Why don't you use AutoCleanup?
Why do you still use that "N" control in the subVI?
Why do you still use DDT wires instead of waveforms?
Can you output AO signals using the example VIs coming with LabVIEW?
Message 17 of 19
(1,344 Views)
Accepted by prasad145
Dear Sir,
              Finally Got the output result for this VI. Thank You for your valuable time support.
Message 18 of 19
(1,328 Views)
Hi prasad,
Open the help for DAQmxTiming function.
Select the "Use waveform" instance.
Read…
Message 19 of 19
(1,318 Views)
