How to append to a file
Ok, it seems my computer went into the 5th dimension...I have two vis with the same diagram (attached test and test2) but only test2 works well for me. I let anyone who's interested try to understand what's happening here...
Thanks everybody for helping me Smiley Happy
Vincent
Message 11 of 18
(1,479 Views)
Hi VdG,
in your test.vi, there you have two functions "Set File Position". The second one is under the "Write to Text File" function. With this function you reset the position to start.
Mike
Message 12 of 18
(1,475 Views)
Can anybody say, are there any difference between the following two VIs? Why they give different results?
Regards
MY
Message 13 of 18
(1,472 Views)
Hi MY NI,
as i already wrote, there is a second "Set File Position" function in the code.
See the attached image.
Mike
Message 14 of 18
(1,465 Views)
Accepted by topic author VdG
Thanks Mike ! you're write. I can't just figure out how it happens to have two functions with icons that exactly overlaps. Now i'm not getting crazy anymore : we live in a logical world.
Vincent
Message 15 of 18
(1,462 Views)
Hi Nike,
you are right. I was jus confused.
Regards
MY
Message 16 of 18
(1,461 Views)
Hi vincent,
Can you please mark mike's reply as the accepted solution?
Message 17 of 18
(1,450 Views)
Hi muks,
i'm sorry : i've not marked the good message from Mike, and now i get an error (sounds like an authentication problem) when i try to cancel the mark.
Vincent
Message 18 of 18
(1,414 Views)
