How to apply a specified load with a frequency of 2hz using Ni9264 and NI9205
Hello please help me
I am using Ni9205 as anlog input card and NI 9264  as anlog output card,
Application requirement is to apply a +ve and -ve load frequently with a frequency of 2hz
For applying the load we are using servo hydrolic cylinder.
The servo cylinder works on +10 and -10 volt signal. If we apply +1v then it goes forward and if we apply -1 then it goes backword.
And increasing the volage increase the speed of cylinder.
Now
I have applied a sine wave to the servo valve. But it does not give equal +and -ve load.
And if i set offset to the wave then it gives more error in the maximum and minimum load.
I have made close loop by finding the maximum and minimum values from the previous samples.
Please somebody give me idea to fullfill this requriment.
(2,588 Views)
in order to help you, it would be useful to upload your VI?
According to your problem description, is it true that your only problem is that you get the wrong + and – ve ?
Greetings and Regards,
James
(2,450 Views)
