How to apply different scales to different channels while recording using cDAQ9171
Hi, I am trying to covert mV/V into Lbs for a cDAQ9171 in LabVIEW. I have 2 signal channels. Now my question is how to apply 2 scales? I am using one Create Channel vi. The LabVIEW diagram is attached below. Thanks for your help in advance. Cong.
(2,483 Views)
I believe the short answer is that it is not possible when you only use one Create Channel.vi. That being said, you may call the Create Channel one time per channel and wire the task out from the first one into the task in for the second one.
Charles
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(2,475 Views)
