How to apply multiple if statements to one input
We are trying to apply multiple if statements to a value of frequency, and want to display a particular string to the front panel depending on whether the frequency is in one of our 12 predetermined ranges of frequencies. Is there a way to do this without creating 12 different case structures?
(2,906 Views)
Accepted by aleto
My recommendation is to make an array of your range limits.  You can then use Threshold 1D Array to get an index value.  Round the index value toward -Infinity.  If you just want to show a different string, then make a corresponding array of strings and use Index Array with the found index value.
(2,904 Views)
