How to arbitrate a "delta t" for chart.
HI,
sorry but my English is not good.
I'm acquiring data from serial port, but my available data have just the amplitude (Y-axis).
I know the delta t is 2 miliseconds.
How to arbitrate de delta t to a Chart?
Can anyone help me?
Message 1 of 11
(4,878 Views)
Set it via the properties dialog for the chart. (Another option is a property node, but make sure to only write it only if needed and not with every iteration)
Message 2 of 11
(4,871 Views)
Which property should I set?
Message 3 of 11
(4,868 Views)
Try "x-scale..offset and incrment..increment" or similar. (Sorry, posting via phone)
Message 4 of 11
(4,861 Views)
Can I do something similar to calculate the power spectrum?
Message 5 of 11
(4,859 Views)
Because my input signal is 500 Hz and the power spectrum is not showing the right value!
Message 6 of 11
(4,856 Views)
Accepted by geovane
You don't need it to calculate the power spectrum, just to dispay it and assign frequencies to the array elements. You can calculate df from dt and N.
Message 7 of 11
(4,850 Views)
why not use "build waveform"?
since you'd have the array of data, and knowing the dt, one could just re-build the signal?
and for the FFT i usually use the express FFT...
Message 8 of 11
(4,838 Views)
If you:
  1. Build a waveform ("Build Waveform" function) from your time-series data, and
  2. Assign 2-seconds to the "dt" waveform component, then
  3. Use the "FFT Power Spectrum" VI from the "Waveform Measurements" pallette to calculate your specturm,
Then you can wire the output directly to a Waveform Graph and the delta frequency and frequency range will be automatically correct!!
Message 9 of 11
(4,834 Views)
I don't use "build waveform" because I acquire the data one point at a time.
Message 10 of 11
(4,832 Views)
