How to assign values for boolean array in LabVIEW?
I want assign values for boolean array.Iam not able to do that.For each boolen i want to assign each value.Plz help me......
(28,691 Views)
Hi agar,
values in an array are "assigned" by building an array (using BuildArray) or by replacing values in an existing array (ReplaceArraySubset)!
Good starting point could be this...
(28,688 Views)
Hi
Can you explain a bit what exactly you want to do when you say assigning values to boolean array?
If i have understood correctly you can assign values by using build array or replace array subset function.
(28,687 Views)
Also,
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(28,681 Views)
If you want to assign the values manually as the program is running, use a boolean array control on the front panel.  The user can push the buttons.
Lynn
(28,662 Views)
Accepted by $agar
Thank you sir...It worked.but i am stucked with other problem.i created a tab control of 4 pages.How is it possible to change the page of 1 tab to Page 2 then to page 3 etc using a boolen control?
(28,627 Views)
Hi
May be this VI will help you ....
(28,613 Views)
