How to auto change the name in X-Axis and Y-Axis in chart ?
Hi, I want to plot data into a chart. I make a selection switch for each channel, there are for temperature measurement and voltage measurement.
What I want is when I switch the selection to temperature measurement, the Y-axis´s name change into Temperature and when it is voltage change into Voltage.
Can LabView do that ?
Citras
Message 1 of 8
(4,129 Views)
There are a lot of things that you could do to make your life easier in your code but here is how I would start with the question that you asked.
Tim
GHSP
Message 2 of 8
(4,124 Views)
Thx for the response, yeah I think my labview program is too complicated. I am still new to labview, I don´t really know how to simplify it.
And for your example that you attached, I can´t open it. My labview is version 10.
Can you tell me what is the name of the components that is used ?
Citras
Message 3 of 8
(4,122 Views)
Property nodes are used to programmatically change properties of front panel objects at run time.  You can generate property nodes in one of three ways:
  1. Right click the control you want a property node for (your graph or enum control) and select Create»Property Node»PropertyYouWantToChange.
  2. On Application Control palette, select a Property Node.  If you do this, you will need to either connect it to a reference of the control or link it to the control directly (right click the node, select Link to»ControlYouWantToLinkItTo).
  3. Hit Ctrl-Space to pop up the quickdrop dialog, then type in Property Node.
This is a use of VI server.  You may want to look at the LabVIEW help for VI server.
Message 4 of 8
(4,116 Views)
Accepted by topic author Citras
Here is a version that should work.
Tim
GHSP
Message 5 of 8
(4,110 Views)
Thx for the solution, one more question, how to create the component in the middle ?
Message 6 of 8
(4,103 Views)
Hi citras,
did you read message #4? Point 2 of that message?
Message 7 of 8
(4,101 Views)
Right click on the graph and follow below
Tim
GHSP
Message 8 of 8
(4,095 Views)
