How to auto scale controls on a pane before mouse release
It seems the auto scale of controls doesn't happen until I release my mouse when I re-size my pane. Is there a way to make it happen while the mouse is down and dragging?
Thanks in advance!
(3,711 Views)
I would ask how your UI is setup.  Are you placing controls on just a normal UI, and then setting the UI to scale all objects?  Are you dragging around splitter bars and such?
This article talks about setting the "Rescale while resize" options as well as dealing with splitters.  Does that cover your use case?
http://blog.eyesonvis.com/2010/06/26/labview-splitter-bars/
(3,675 Views)
Hi Shane-C,
Thanks for your reply, and the article is a good.
I setup the my UI by
  1. Select File»VI Properties to display the VI Properties dialog box.
  2. Select Window Size from the Category pull-down menu.
  3. Place a check mark in the Scale all objects on front panel as the window resizes checkbox.
It does meet my most of need except that the controls on a pane doesn't scale until I release mouse after re-sizing the pane.
To be more specific, this is what I observe:
    1. I hover my mouse at the lower right corner of a pane.
    2. I drag that corner to re-size my pane, and the controls in the pane don't scale while I am still dragging the window.
    3. The controls do scale after I release my mouse.
This behavior looks a little awkward if a user drag the window to re-size it and hold the mouse down for a while. It will be more pleasant if the controls scales while the user is dragging the window's border or corner.
I hope the explanation helps.
(3,665 Views)
Accepted by topic author littlett01
Ah, I see, the explanation helps.  There are lots of programmatic ways to do this, but the simplest method is to right click on the panel as shown in this image and set it to resize while scaling.
(3,658 Views)
Awesome! Thanks a lot!
Yong Liao
(3,653 Views)
