How to avarage 2D arrays
@sara14 wrote:
"Where did you read what, exactly??" when I put a shift register, I should connect the inlet/outlet tunnels for the false case.
Only if you want to retain the existing value unchanged. Don't blindly follow random suggestions without understanding the reason.
Message 21 of 22
(706 Views)
Thank you altenbach,
in most cases I try to google in and read more, but sometimes I cant find a proper explanation. And since programming is not my maijor and I have a limited time to finish my vi, I make mistakes. Now, I am reading state machine as you mentioned and trying to figure out how to apply it for my case
Thank you very much and so sorry again
Regards
Message 22 of 22
(697 Views)
