How to average values corresponding to repeated values in a column.
The data is in the.xls format  having two coulms of floating data type.
Message 11 of 12
(1,003 Views)
Hi Jimmy,
no, it's not in an "xls format"…
- ReadSpreadsheetFile will load a formatted text file with some delimiters between your data items
- NEVER compare floating point numbers for equality. You will find a lot of threads in this forum on exactly this matter…
- You're not a friend of the AutoCleanup tool? And you don't like snippets either?
When the first column contains just integer values I would go with Variant attributes. Each attribute would collect the "2nd row values" for a unique integer item…
Message 12 of 12
(995 Views)
