How to avoid using property nodes
I have a problem with the speed of my program.
When using property nodes, Labview becomes very slow. I want to do the following:
- read a number of data
- Only if a value changes, or a value suits certain conditions, put the value in an array.
- hence, the created array contains only those values that are of interest to me.
At the moment I use a property node (value) inside a case structure. If the value corresponds to my criteria, the case is true, and the value passes through to the property node (value) which links to a numerical control outside the case structure.
If the value does not correspond to my criteria (case = false), nothing happens, and the numerical control maintains the last value. (Hence, the case structure has no wired outputs, because then a value would be necessary for the false case).
This works, but this is very slow, due to the property node function. How can I do the same, but without the need to use a property node?
Attached is a small labview 7.1 VI that shows the problem
Thijs
Message 1 of 9
(5,058 Views)
Hi Thijs,
Have a look at this VI and feel free to ask if you need more help.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 9
(5,051 Views)
Thanks TiTou, I hadn't thought of the use of shift registers yet!
You are restricted to use a loop though, but a FOR loop with a loop count of 1 does the job beautifully well!
Thanks!
Thijs
Message 3 of 9
(5,020 Views)
Thijs,
Depending on what you want to do, you don't alway need a shift register to do that.
Also I added other ideas with comments in the attached file.
Hope that will be a usefull source of inspiration for the future...
Epictetus
Antoine Chalons
Message 4 of 9
(5,015 Views)
The idea is to keep the last value as output, and not to use NaN instead.
Any idea how to get rid of the FOR loop?
See attached VI
Thijs
Message 5 of 9
(5,012 Views)
If the indcator should only update under certain conditions, place it inside the case structure. No need for a FOR loop. 🙂
Message 6 of 9
(4,999 Views)
Since you connected a "1" constant , the for loop will run just once... so the for loop is totally useless in your code. You will see no difference if you remove it.
Epictetus
Antoine Chalons
Message 7 of 9
(4,994 Views)
It seems to me that you are using the For loop just so you can use the shift register to keep the previous value of the mean from the last time the program was run. Perhaps you could use a local variable?
Image hosting by TinyPic
(By the way, there was recently a very enlightening thread about the best way to discard data in an array that is outside of a certain range. You may find it interesting: http://forums.ni.com/ni/board/message?board.id=170&message.id=175488 )
Message 8 of 9
(4,994 Views)
Why???
Personally, I almost always prefer shift registers over local variables, but in this case we don't need either. Look at my example above (http://forums.ni.com/ni/board/message?board.id=170&message.id=177091#M177091), if the terminal is inside the case structure, it will automatically retain its previous value until the case turns TRUE again in the future. 🙂
No local needed. 😄
Message 9 of 9
(4,971 Views)
