How to break out of a sequence structure
Is there a way to break out of sequence structure?
(9,518 Views)
Accepted by aderogba
No. That is one of the reasons that sequence structures are often frowned upon. Far better to rewrite the code to be a state machine.
(9,510 Views)
Hello, I am just a beginner in labview.. May be this is not the solution to your question but i'm simply posting what i did in my project a couple of months before2234.PNG..Smiley Very Happy
(9,486 Views)
What was suggested above technically will work but the whole point that Dennis was trying to make is that you shouldn't write your program in this way. LabVIEW is a dataflow language, not a sequential language. Take the time to actually learn the techniques associated with dataflow programming and use them. It is a VERY powerful programming paradigm. Sequence frames should be used very sparingly and only for very specific reasons. Generally they should only be used for sequences that will always run the complete sequence and where no data flow exists. The perfect example is the technique used to time a block of code. A three frame sequence is used with a Get Time in the first and last frames and the code you want to time in the middle frame. A single frame sequence is often used to impose article dataflow. Other than that try to avoid using sequence frames. Do yourself, and anyone who may need to maintain your code later on, and learn dataflow programaming.
Also, the above example is not very good code since it is using multiple local variables. In general local and global variables should be avoided since they also break the dataflow programming paradigm and can lead to race conditions in your code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(9,474 Views)
Thanks for the feedbacks; I will re-wrtie my code.
(9,437 Views)
Hello Mark,
                I read what you have written and accept it. Thank you for your advice. I will try to learn the data flow programming and deliver better results.
Nitzy
(9,407 Views)
