How to bring mouse cursor to the default button of a dialog, like in windows
Hi Patha,
I was almost at breakfast, it must be the reason why I forgot that Smiley Sad
greets, Dave
Greets, Dave
Message 11 of 13
(674 Views)
Dave,
First, thank for your help. Smiley Happy
What you VI does is to bring/move the mouse cursor to the control that is referenced.
What I want is to make my a VI detect the default highlighted button in a dialog window & move/bring the mouse cursor over it automatically, not by wiring its reference manually.
Is there any way to achieve what I wish to?
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 13
(654 Views)
Hi partha,
here is an example for you. I saved it for LV8.0 so there are some errors in it, because the dll node in 8.0 has no error in and out connector. If you remove the errors it works for you. First it gets the foreground window and then the control with the focus. To make what you want, you have to insert the function "GetWindowRect" to get the position of the control with the focus and then the mouse move command.
Hope it helps.
Mike
Message 13 of 13
(642 Views)
