If memory is your problem, save the data to a file.
I would then build my own display and scrolling routine to go through the read-in data.
The output of the routine is sent to the wavefrom graph. At full view, don't show all data-points but 1 in every 10 or 100, or the local min and max-values if you want to find a short event.
