problems exporting datasocket java bean
hi,
i used the datasocket java bean to program an applet using IBM's VisualAge for Java. although the applet works when i run it on my computer, after i export it to another computer it doesn't (i'm able to run the applet but the datasocket doesn't connect).
does anyone know how to solve this?
thanks,
jon.
(3,050 Views)
Hi, check if the port for dataSocket is available,and if the dataSocket servermanager permit the remote machine to write on it. remember that applet only can comunicate with the machine fron they came out, I recomend you the boock internet application in labview from Jeffrey Travis.
By
(3,050 Views)
