02-22-2009 09:26 PM
hi
I need to show the power flow . From previous post, I learned that arrow-like slider can work. But I am a novice, I don't know how to make it. Can anyone tell me the information of making a special control? Thanks a million.
regards
Jessie
Solved! Go to Solution.
02-22-2009 09:41 PM
You open the control editor and replace the normal image that is associated with the slider with one that is an arrow. Do a search on the forum for "customizing controls" and see what comes up. There have been some very good descriptions of the process in the past.
Mike...
02-22-2009
09:51 PM
- last edited on
05-02-2025
07:46 PM
by
Content Cleaner
Hi Jessie,
Rright click on the control you want to customize and select "Advanced -> then select Customize, this brings up one more frontpanel --then select import picutres to clipboard from Edit Menu into the control (Edit -> Import Picture to clipboard) ---then paste it into the control by pressing Ctrl+V . when finished, save the control so it can be used later.
Check out this link for detailed help.
02-22-2009 11:37 PM
VENKATESH…
Thanks for your valuable suggestion. I am now studying the webpage of creating custom controls,indicators,and type definitions. I have a question, can't I delete the parts of the controls?
Jessie
02-24-2009 08:38 AM
02-24-2009 08:45 AM
flysinger wrote:VENKATESH…
Jessie
No but you can squish them down, hide behind other stuff or can be painted transparent.
Ben
