How to calculate Day of Year
Is there a quick and easy way to convert the Day of month, Month and Year to Day of Year?
Message 1 of 21
(9,487 Views)
you can use get date/time string.vi and date format should be set to long
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 21
(9,481 Views)
Convert a timestamp using the 'Format into String' function and a format of  %<%j>T. If you need the number, then convert the output using 'Decimal string to Number'
Message 3 of 21
(9,477 Views)
Yet another way.
Message 4 of 21
(9,471 Views)
Or you could use Format Date/Time String, with the format string set to %j
Message 5 of 21
(9,398 Views)
Hello, how do I do this for with the current time.
Message 6 of 21
(8,248 Views)
Use the Seconds to Date/Time function and unbundle the Day of Year.  Do not have an input for the Seconds to Date/Time node as it defaults to the current time.
GCentral
Message 7 of 21
(8,239 Views)
Thank you 🙂
Message 8 of 21
(8,228 Views)
how do I get month of year? is there any vi to get that?
Message 9 of 21
(7,714 Views)
Same way as CrossRulz mentioned in his post.
Look at the Help for that function.  It has numerous outputs that could be useful for you.
Message 10 of 21
(7,703 Views)
