How to calculate slope of XY curve?
Hi all,
I want to calculate the slope of a X-Y curve, for example, amplitude v.s. position. I was trying to use the derivative method but failed. Could anyone help me with this problem? The example vi. is attached.
Nicky.
Message 1 of 10
(15,774 Views)
Accepted by Nicky87
Like this
Tim
GHSP
Message 2 of 10
(15,768 Views)
Dang it, too slow...
Try the Linear Fit VI
Message 3 of 10
(15,766 Views)
Although it involves a Rube method as compared to Linear Fit, the attached vi teaches what a slope really is.
- tbob
Inventor of the WORM Global
Message 4 of 10
(15,698 Views)
Can you post the same solved example with labview 8.2?
Message 5 of 10
(15,375 Views)
Here is an 8.0 version.
Tim
GHSP
Message 6 of 10
(15,358 Views)
Hey
Attached is the Vi.
Could you please help me if I want to find the slope and I want to stop the loop and measurement when the maximum slope has been attained.
Help will be very much appreciated.
Message 7 of 10
(15,330 Views)
How are you defining "maximum slope".  Is it a simple threadhold (stop when slope >= a set value) or are you looking for the inflection point (calculating on the fly the maximum slope and stopping when it is reached)?  The threshold is a simple comparison.
Message 8 of 10
(15,325 Views)
No it is infection point, as in after getting the measurement value , finding the slope and stopping when the slope is highest as in it has maximum deviation from the previous value.
Message 9 of 10
(15,323 Views)
You should be having a Max limit value so that you can compare on the fly and stop if the max slope is achieved. Check the attached example and also keep it in a single thread
Good luck
Message 10 of 10
(15,297 Views)
