How to calibrate the PCI-6110 using NI-DAQmx
I am a new user of the PCI-6110 board trying to run the calibration procedure using LabVIEW. I'm looking at the "Calibration Procedure" document on the Manuals page for the board,
http://sine.ni.com/nips/nisearchservlet?nistype=psrelcon&nid=11888&lang=US&q=FQL:%28locale%3Aen%29+AND+%28phwebnt%3A1081+OR+phwebnt%3A7075%29+AND+%28nicontenttype%3Aproductmanual%29+AND+%28docstatus%3Acurrent%29%20RANK%20nilangs:en&title=NI+PCI-6110+Manuals
One of the first steps in the document is to call the AI_Configure command to set the input mode, range, etc. I am using LabVIEW 8.5 with the NI-DAQmx software, and I can't find the command (which in LabVIEW seems to be "AI Config.vi") anywhere. The calibration document was written in 2003, and I gather from Google searches (please correct me if wrong) that this command is actually part of Traditional NI-DAQ, which has been superseded by the NI-DAQmx driver software.
My question is this: what is the equivalent command to AI_Configure in the newer software? Is there perhaps a later document describing how to calibrate using NI-DAQmx?
Many thanks for any help,
Tom McLaughlin
(6,833 Views)
Accepted by thomasjm
Hi Tom,
The B/E/M/S Series Calibration Procedure, which is also linked from that page, describes how to calibrate the PCI-6110 with NI-DAQmx.
Brad
Brad Keryan
NI R&D
(6,827 Views)
Aha. Thanks! That solved my problem.
(6,815 Views)
You should mark Brad's answer as the solution and not your thank you. You can change the marked solution by clicking on 'Options'.
(6,805 Views)
