How to call a labview dll from excel-VBA?
How to call a simple Labview DLL from Excel VBA?
I have seen examples of DLL calls from VB but does it work the same way for VBA? I have 2000 excel and Labview 8.5. I created the DLL and tried to call it from VBA using the same type of code as in NI's website example(ofcourse its a bit diff with 8.5)
http://zone.ni.com/devzone/cda/tut/p/id/...
BUT it errors out when called from excel
ERROR: The object invoked has disconnected from its client
(4,162 Views)
You would need to provide more details about the LabVIEW DLL, such as the prototypes of the functions (VIs) that you're trying to call, and your actual VBA code. Specifically, what object you're trying to create. You should also make sure the Run-Time Enginer is installed, as well as any required libraries such as the VISA Run-Time if you're using VISA. Have you made sure to enable the ActiveX server for the DLL?
A search yielded the following items that you may wish to peruse:
http://forums.ni.com/ni/board/message?board.id=170&message.id=261345&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=45099&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=299209&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=195846&requireLogin=False
(4,140 Views)
