Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to call dll files in Labview using Call Library Function?
pengwei
Member
07-09-2003
01:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
In LV6.1 or LV7,I can use Call library function to call a dll file.So I can see these Function Name listed in CLF dialog.But in LV5.1,when I use CLF to call it,the Function name isn't showed.
How could I use this dll file in LV5.1?
Thanks!
0
Kudos
Message
1
of 3
(3,165 Views)
Reply
Re: How to call dll files in Labview using Call Library Function?
Oleg
Active Participant
07-09-2003
02:23 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you must type the name of function manually in 5.1 version.
Good luck.
Oleg Chutko.
0
Kudos
Message
2
of 3
(3,164 Views)
Reply
pengwei
Member
Author
07-09-2003
05:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks!
0
Kudos
Message
3
of 3
(3,164 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
