doing data acquisition and freq measurement simultaneously
Iam acquiring data from NI-PXI4472 as well as measuring frequency from NI-PXI-6602 counter card,When my counter doesn't receive any signal,my counter generates a buffer read error & stops,still my acquisition runs,but my acquisition rate becomes slower
(2,573 Views)
It seems like you need to give more thought to your program architecture. A good measurement application must be written to handle signal loss gracefully. The fact that your acquisition rate changes based on an error condition leads me to believe that you are using software timing instead of hardware timing. You've got two super-powered pieces of hardware in the 4472 and 6602. Let them be your timing sources. Acquisition rate (or scan rate) does not change when you set it in hardware.
All these things come with experience. You may benefit greatly by hiring an Alliance Member to get you past the initial hurdle. We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,573 Views)
Hi, Thanks for your reply. can you give me a breif detail about hardware timing.
(2,573 Views)
