How to call sequence in LabVIEW by providing sequence file path.
    Please provide me a solution to call sequence file from LabVIEW ActiveX API's by inputting sequence path to LabVIEW user interface.
Thank you
Yuvaraj
(3,903 Views)
You are referring to a TestStand sequence file?
Do you want to run the sequence file?  Such as Execute-> Single Pass, Test UUTs automatically in LabVIEW?  Or are you looking to OPEN the sequence file in LabVIEW?
PH
(3,885 Views)
Yes its Teststand sequence file.
I want run the sequence file(Single pass) in LabVIEW.
Yuvaraj
(3,865 Views)
Accepted by YuvarajaGK
Here is a link that I gave some pointers on how to run an Open Sequence file via Single Pass.
http://forums.ni.com/t5/NI-TestStand/Direct-execution-of-the-sequence-when-UI-launches/m-p/2000819#M...
How are you launching this sequence, is the user selecting the sequence on disk?    Is it already open in a SequenceViewMgr control?
Would an operator interface be more applicable to your situation?
PH
(3,848 Views)
Thank you for your help. Everything working fine.
Regards-
Yuvaraj
(3,825 Views)
