How to carry the temperature data every 10 minutes once
I used the NI6221-PCI card to carry the temperature signal. Now I encounter a very difficult problem. I want to carry the temperature data every ten minutes a time(only one data) and for total ten times. At last, I calculate and get the average value.  I had tried a lot of methods,but failed. How to deal with it???
Thanks in advance
cheng_bei
Message 1 of 8
(3,649 Views)
Hi cheng_bei,
see this "Cont Acq Thermocouple Samples-SW Timed.vi" example from the example finder and change it to your needs.
If this isn't what you need, then please explain a bit more about what you have done and where you have problems.
Mike
Message Edited by MikeS81 on 05-04-2010 03:20 PM
Message 2 of 8
(3,646 Views)
Hi Cheng,
There is a 'Mean' vi somewhere but i couldnt (be bothered to) find it.
This will take your measurements then exit displaying your mean and test results
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 3 of 8
(3,631 Views)
Let me get that right. You want 1 Temperature reading every 10 minutes and take an average (of 10 readings) every 100 minutes?
Is that correct?
Message 4 of 8
(3,616 Views)
Thank you.
Message 5 of 8
(3,592 Views)
Thank you. Lucither!!  I will try it.
Message 6 of 8
(3,591 Views)
Hi, Dimitrios:
Yes,it is.
Message 7 of 8
(3,590 Views)
Hi Cheng,
I just realised that i never added a stop button for you to exit the vi with, here is a different version:
Rgs,
Lucither
Message 8 of 8
(3,575 Views)
