How to change 3D data to 2D data ?
HI,all
I  have a 3D data like following picture
I want  change to 2D data  like following picture
How can I do?  THANKS~
(3,730 Views)
In your desired result I only see a 1D array, what is the second dimension?
Also, where is this data being generated? It looks like the array might be being formatted incorrectly to begin with. Could we see the code where the array is being created?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,720 Views)
sorrry.. The title must change 3D array to 1D array
This is my VI. but you might can't run this, because it's contain scope card.
(3,712 Views)
(3,710 Views)
Why don't you just use the Auto-indexing tunnels on the FOR loops?  The code in there can become a lot simpler.
(3,703 Views)
I can open your VIs, but I don't see where the 3D array is coming from. The outputs of the express VIs are a 2D array. The loops extract the first 15 columns of each row and after a bit of scaling, extracts the maximum value from each row. The two loops will each generate a 1D array. See crossrulz post to see how this part could be done more efficiently, but for now my main question is:
Where do you get the 3D array?
Mike...
LabVIEW Champion
(3,698 Views)
