How to change a specific bit to 0 or 1?
i think i have an easy problem but i dont get the solution.
What is want to do is a vi with this parameters:
Input:
current-value (U32)
BitNumber (0..31)
State (Bool)
Output:
new-value (U32)
for example if
current-value = 00000000 00000000 00000000 00000111 (binary)
BitNumber = 2 (dez)
State = False
Then the new-value should be: 00000000 00000000 00000000 00000011 (binary)
With same parameters and State = True the new-value is unchanged because ithe bit is already true.
How do i do this?
Message 1 of 30
(5,939 Views)
Hi OnlyOne,
here is one solution for you.
Mike
Message Edited by MikeS81 on 05-06-2008 11:06 AM
Message 2 of 30
(5,926 Views)
this is a nice problem. Hope this helps
greets, Dave
P.S. Mike, it's hard to beat you Smiley Very Happy
Message Edited by daveTW on 05-06-2008 11:12 AM
Greets, Dave
Message 3 of 30
(5,922 Views)
But i will try it with a perharps more generic solution since you can mask more bits at a time:
hope this helps,
Norbert
Message Edited by Norbert B on 05-06-2008 04:18 AM
Norbert
Expert: Geometry
Message 4 of 30
(5,912 Views)
Hi Mike,
thank you for your fast answer.
I was always trying to solve it like Dave and didnt think about the way that you did it (which is much easier to understand).
thx
Message 5 of 30
(5,910 Views)
Nice solution Norbert,
but what´s that? Smiley Happy
Mike
Message Edited by MikeS81 on 05-06-2008 11:21 AM
Message 6 of 30
(5,906 Views)
Your problem is indeed easy to solve ! Among several other solutions :
Message Edité par JB le 05-06-2008 11:24 AM
Message 7 of 30
(5,900 Views)
OMG, Mike found a "nearly WEQ" in my example 😉
BUT, it is not really a WEQ (sure in this screeny), but the boolean constant is the way to determine if to switch 0=>1 or 1=>0.... I'd better document that in the future......
Norbert
EDIT: I know that this could be done by switching True-case to false and vice versa as well.... But i think (even if its currently a WEQ), it is more readable......
Message Edited by Norbert B on 05-06-2008 04:28 AM
Norbert
Expert: Geometry
Message 8 of 30
(5,886 Views)
A few minutes to make an example and I must note that others have already posted a lot of answers and comments. You are really too fast !
Message 9 of 30
(5,877 Views)
Here the reworked example as vi, maybe someone could use it......
Norbert
Norbert
Expert: Geometry
Message 10 of 30
(5,870 Views)
