How to change a specific bit to 0 or 1?
Hi Natasha,
@Natasha1994 wrote:
Will it also work in a reverse order ? To change 0 to 1 ?
Sure - as soon as you use the correct mask and the correct boolean operation (as mentioned above)…
Message 21 of 30
(1,209 Views)
Bitwise and shift operators - perform boolean (AND, NOT, OR, XOR) and shift operations on individual...
C# reference, but the logic is the same
Qestit Systems
Certified-LabVIEW-Developer
Message 22 of 30
(1,201 Views)
Here's what I might do:
Message 23 of 30
(1,190 Views)
Here's a more general version where you can freely select all the bits you like to toggle:
Message 24 of 30
(1,175 Views)
Because I am TERRIBLE at bitwise operations, I usually translate the numbers into Booleans so I can manipulate them "directly".  It is more important to me that the results are accurate than me trying to be efficient.  I know most people prefer to manipulate the numbers directly using bitwise operations.  I just have a mental block about them.
And anecdotally, I've never seen an instance where Booleans were used that the results were incorrect; on the other hand, I've found plenty of instances where bitwise operations were performed incorrectly leading to erroneous results.
Bill
CLD
(Mid-Level minion.)
Message 25 of 30
(1,169 Views)
Disagree! I've seen plenty of cases where boolean operation were incorrect (especially here in the forum, not with my own code!, of course!), OTOH, bitwise operations on unsigned integers are identical to boolean operations. If they are incorrect, the underlying boolean operation was already incorrect. 😄
Substituting boolean operations for bitwise, gives you a dramatic penalty (8x more memory per bit!), and adding the conversion overhead adds to the expense.
Message 26 of 30
(1,164 Views)
I think of it as calculating which switch to throw vs just looking at the switches and throwing the right one.  And unless I am going to do this 1000x in a FOR loop, I don't really care if it takes a split second longer or multiplies my memory usage by 8x per bit.
To me, it's much easier to visualize which bit to flip than to calculate it.  And I've seen bad mask calculations a lot more than bit miswirings.
Bill
CLD
(Mid-Level minion.)
Message 27 of 30
(1,146 Views)
I do that in a develop/test stage many times, or just use a binary display of a number.
Qestit Systems
Message 28 of 30
(1,119 Views)
I never thought of that!!!  I could do an explicit Boolean conversion to check my blind spot bitwise operation for validity!  Then I could have the best of both worlds.
Bill
CLD
(Mid-Level minion.)
Message 29 of 30
(1,116 Views)
I also like the binary display when dealing with bit-wise logic.  It works well for 8 or 16-bit integers.  Once going for a 32-bit or 64-bit, it becomes unwieldy and I switch to hex display.
Message 30 of 30
(1,107 Views)
