How to change csv file to dat file
I want ask you about the data that i got.
Actually, the data in csv file. So, can i change directly file to dat file? Just put c:\Trace.dat?
can or not?
Need your help.
Thank you.
Message 1 of 16
(13,905 Views)
Message 2 of 16
(13,896 Views)
thanks.
I have done download. so, what the function is?
Need your help.
Message 3 of 16
(13,885 Views)
Didn't you read the information given in the link?
" This DataPlugin supports the reading and writing of CSV files with various separators like comma, semicolon, tab, or others.
The CSV DataPlugin is installed by DIAdem and LabVIEW by default. If your CSV files require specific treatment to read all information into DIAdem and LabVIEW, you can use the DIAdem DataPlugin Wizard to write your own DataPlugin.
File Extension: *.DAT
Direction: Read / Write
Last Change: Released with current LabVIEW and DIAdem versions
You can also try this link if you want more specific information
http://www.ni.com/white-paper/13789/en
T
Message 4 of 16
(13,882 Views)
Do you just want to change the extention (which does nothing to the file) or are you trying to change the file format?  And what format do you want if you are changing that?
Message 5 of 16
(13,851 Views)
Thank you.
I just want to change the file format. Previously, the format is in .csv file. Now I want to change to .dat files.
How the process?
Need your help.
Message 6 of 16
(13,849 Views)
What is the format of the dat file?  There is not really a set definition for dat files.  So it is a matter of how you want to store your data.
Message 7 of 16
(13,847 Views)
Actually this format in MATLAB software. So, i want this dat format because I want to simplify my data imported directly into the software.
Message 8 of 16
(13,842 Views)
This should do it: CSV_to_DAT.png
This will only work with numbers, I think to do text you have to add the matlab headers.
Message 9 of 16
(13,837 Views)
And what is the format that is defined?  Or are you referring to MAT files, which are binary files specific to Matlab?
Message 10 of 16
(13,816 Views)
