How to change csv file to dat file
The format is this from the matlab documentation:
The following remarks apply to loading all ASCII files, even when you do not include the -ascii keyword, but load a file with an extension other than .mat:
  • The file must contain a rectangular table of numbers, with an equal number of elements in each row. The file delimiter (the character between elements in each row) can be a blank, comma, semicolon, or tab character. The file can contain MATLAB comments (lines that begin with a percent sign, %).
  • MATLAB returns the data as a single two-dimensional array of type double. The number of rows in the array is equal to the number of lines in the file. The number of columns is equal to the number of values on a line.
  • If you do not specify an output for the load function, MATLAB creates a variable named after the loaded file (minus any file extension). For example, the command
    I think you can do strings with it also, but it requires undocumented stuff with the comment lines.
Message 11 of 16
(2,064 Views)
If that's the case, I don't see a reason to change the file.  It looks like MATLAB will read your CSV file just fine.
Message 12 of 16
(2,050 Views)
This is my block diagram. The data is in csv file. So, i want save data in dat file. How the process?
Need your help.
Thank you.
Message 13 of 16
(2,038 Views)
Again, what exactly are you trying to do?  Why are you trying to change the data format?  If you just want to read your file in MATLAB, it looks like it will already read comman delimited files, therefore you don't need to do any conversions.
Message 14 of 16
(2,030 Views)
Yeah, when I wrote my response originally I didnt realise that matlab can do anything other then files seperated by spaces or tabs. The only thing it wont read most likely would be a csv file with text mixed with numbers. In that case the MATLAB "csvread" function would probably work.
Message 15 of 16
(2,026 Views)
Accepted by topic author NurHidayah
Nur, as the others mentioned, try reading your MAT file, it should read without any issues.
Message 16 of 16
(2,001 Views)
