04-18-2013 02:17 AM
I want ask you about the data that i got.
Actually, the data in csv file. So, can i change directly file to dat file? Just put c:\Trace.dat?
can or not?
Need your help.
Thank you.
Solved! Go to Solution.
04-18-2013 03:06 AM
Try this link http://zone.ni.com/devzone/cda/epd/p/id/6595
04-18-2013 03:54 AM
thanks.
I have done download. so, what the function is?
Need your help.
04-18-2013 04:04 AM
Didn't you read the information given in the link?
" This DataPlugin supports the reading and writing of CSV files with various separators like comma, semicolon, tab, or others.
The CSV DataPlugin is installed by DIAdem and LabVIEW by default. If your CSV files require specific treatment to read all information into DIAdem and LabVIEW, you can use the DIAdem DataPlugin Wizard to write your own DataPlugin.
| File Extension: | *.DAT |
| Direction: | Read / Write |
| Last Change: | Released with current LabVIEW and DIAdem versions |
You can also try this link if you want more specific information
http://www.ni.com/white-paper/13789/en
T
04-18-2013 08:03 AM
Do you just want to change the extention (which does nothing to the file) or are you trying to change the file format? And what format do you want if you are changing that?
04-18-2013 08:11 AM
Thank you.
I just want to change the file format. Previously, the format is in .csv file. Now I want to change to .dat files.
How the process?
Need your help.
04-18-2013 08:35 AM
What is the format of the dat file? There is not really a set definition for dat files. So it is a matter of how you want to store your data.
04-18-2013 09:08 AM
Actually this format in MATLAB software. So, i want this dat format because I want to simplify my data imported directly into the software.
04-18-2013 09:41 AM - edited 04-18-2013 09:47 AM
This should do it:
This will only work with numbers, I think to do text you have to add the matlab headers.
04-18-2013 10:23 AM
And what is the format that is defined? Or are you referring to MAT files, which are binary files specific to Matlab?
