How to change elements in a cluster from an event loop?
Due to time constraints, I have this application working with local variables.  I used a different signal to control the data flow to ensure correct order of initilaisation at startup.
We have identified enough areas of improvement to warrant a big restructure of the program in the future when time permits.
Thanks for the advice and ideas, we will refer back to this post when doing that restructure.
Ashley
Message 11 of 11
(698 Views)
