How to change hexadecima​l
Hello All,
Question: How to change the HEX ? Please see the problem below.
2f287 -> d0d78
Message 1 of 13
(4,782 Views)
I don't understand what your question is.  You can change the way a number is displayed by changing the display format of the control or indicator.  The value can be displayed as decimal, hex, octal, or binary.
Is that what you want?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 2 of 13
(4,773 Views)
Accepted by CP_AT
Message 3 of 13
(4,770 Views)
OK, that works the way you have it.  What's your question?  What problem are you having?
Kelly Bersch
Message 4 of 13
(4,766 Views)
First, I want to send my 1st HEX number (2E287) to my device. Then, I want to reverse all the binary numbers (0 to 1 & 1 to 0).As the result, the new HEX (D1D78) will generate and send to my device again.
Hopes it clear.
Message 5 of 13
(4,765 Views)
I got this far
Message 6 of 13
(4,755 Views)
Here is my problem diagram
Message 7 of 13
(4,745 Views)
Try this:
Kelly Bersch
Message 8 of 13
(4,744 Views)
Have either of you actually tried Jeff's solution?
Message 9 of 13
(4,740 Views)
I actually missed his solution as I was working on things.  It's cleaner than mine.
Kelly Bersch
Message 10 of 13
(4,731 Views)
