How to change raw char string to 16-bit 2's complement integer?
Please see the following raw char sting
óèóóóóþþóèþóóóþóþóóèþóóóóóóóóóþóóóóóèóóóóóþóóþþóóóþóèóóþóèþóèóþóóþóóèþóóóþèóóþóþóþóóóþóóóþóèóþþèþóþó
How could I converter it to 16-bit short signed integer 2's complement?
Ott
(3,905 Views)
Accepted by Ott
What do you expect for the output?  Something like this?
(3,896 Views)
Yes- how to achieve it?
Thank,
Ott
(3,889 Views)
Thank,
Ott
Jim
(3,872 Views)
I used the Unflatten From String primitive.  Wired in an array of I16 to the data type and a FALSE to the "Contains Array or String Size".  You can also save off that picture I gave you earlier.  It is called a snippet.  Just drag your saved copy onto a clean block diagram and you will have the code.
(3,869 Views)
